[postgis-devel] [PostGIS] #767: Ndims does not exists Error
    trac at osgeo.org
    Wed Jan 12 10:04:25 PST 2011
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by aperi2007):
 I try same query sql with the last r6604, but still having the error:
  ERROR: function ndims(geometry) does not exist
   Suggerimento: No function matches the given name and argument types. You
 might need to add explicit type casts.
   Dove: SQL statement "ALTER TABLE ONLY
 caricamento._csr_map_crop_multiline
                                                  ADD CONSTRAINT
 enforce_dims_st_boundary
                                                  CHECK (ndims(st_boundary)
 = 2)"
 PL/pgSQL function "populate_geometry_columns" line 97 at istruzione
 EXECUTE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/767#comment:1>
