[postgis-devel] [wktraster] Core tests failure for r5841
Paragon Corporation
lr at pcorp.us
Wed Jan 12 14:10:50 PST 2011
Pierre,
I get the same answers you get : -32768, -32768
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Pierre
Racine
Sent: Wednesday, January 12, 2011 1:47 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] [wktraster] Core tests failure for r5841
Jorge, Regina,
I get a fresh build of PostGIS raster and the regress test in rt_addband.sql
fail on my machine. It was modified by Mateusz which was obtaining different
results.
In the first case:
SELECT St_Value(ST_AddBand(ST_MakeEmptyRaster(1000, 1000, 10, 10, 2, 2, 0,
0, -1), 1, '16BSI', -32769, NULL), 3, 3);
Mateusz gets 32767 and I get -32768
In the second case:
0, -1), 1, '16BSI', 210000.46, NULL), 3, 3);
Mateusz gets 13392 and I get -32768
I suspect this is a Windows/Linux difference. Do the test works/fails for
you? What results do you get?
Pierre
>From: Mateusz Loskot [mailto:mateusz at loskot.net]
>Sent: 4 septembre 2010 14:28
>Cc: Pierre Racine
>On 31/08/10 21:14, Pierre Racine wrote:
>>>From thoses two lines in the rt_addband.sql file:
>> 2, 0, 0, -1), 1, '16BSI', -
>> and further:
>Pierre,
>I'm still confused why you are getting such strange values.
>The value -32768 is invalid and unexpected, obviously.
>It would indicate a bug.
>Fortunately, I do not get such value, but I get the correct ones:
>r1=# SELECT St_Value(ST_AddBand(ST_MakeEmptyRaster(1000, 1000, 10, 10,
>2, 2, 0, 0, -1), 1, '16BSI', -32769, NULL), 3, 3);
>WARNING: Initial pixel value for 16BSI band got truncated from
>-32769.000000 to 32767 st_value
> 32767
>(1 row)
>2, 2, 0, 0, -1), 1, '16BSI', 210000.46, NULL), 3, 3);
>210000.460000 to 13392 st_value
> 13392
>(1 row)
>Nevertheless, I've updated the expected output with correct values:
>http://trac.osgeo.org/postgis/changeset/5907
>Best regards,
>Mateusz Loskot, http://mateusz.loskot.net Charter Member of OSGeo,
>http://osgeo.org
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
