[postgis-devel] [PostGIS] #768: Probe_geometry_columns() don't work correctly
trac at osgeo.org
Thu Jan 13 11:37:06 PST 2011
Reporter: aperi2007 | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: invalid | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => invalid
Comment:
Andrea,
For some reason I got confused and thought you were talking about
populate_geometry_columns(). Unless I'm mistaken, probe_geometry_columns
will only added entries to geometry_columns table if your table has srid
and geometry dimension constraints where as populate_geometry_columns will
add by inspecting you data and also add constraints to your table if its
missing contraints.
Given that you created your table with a create as statement, you don't
have contraints on the table. So I'm going to mark this as invalid and
close it out.
Feel free to reopen if you feel I'm mistaken and it worked with this set
in 1.5.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/768#comment:5>
