[postgis-devel] [PostGIS] #502: [raster] Optimize ST_Intersection to return ST_Value when intersecting with points
trac at osgeo.org
Thu Jan 13 15:00:41 PST 2011
points
Reporter: pracine | Owner: pracine
Type: enhancement | Status: assigned
Priority: low | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Resolution: | Keywords:
Comment(by pracine):
I'm still thinking anout it and consult our big PostGIS raster lidar freak
user here (Etienne) to try to find the best options possible. At a first
glance:
-There should be an option saying to ST_Value should return nodata value
as NULL or nodata value. NULL by default.
-There should be an option to specify which one of the four pixel value to
return when the point geometry falls on the edge of 2 or more pixels.
-ST_Value should continue to return only one value; use ST_Intersection if
you want a vector-like behavior with pixel edges (i.e. possibly many
values).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/502#comment:10>
