[postgis-devel] [PostGIS] #593: [raster] Add a ST_BandIsNoData function
PostGIS trac at osgeo.org
Fri Jan 14 05:27:32 PST 2011
 Reporter:  pracine         |       Owner:  jorgearevalo
     Type:  task            |      Status:  assigned
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by jorgearevalo):
 Ok, approach used:
 1.- Check if the band is a NODATA band inside the band creation functions
 (rt_band_new_inline, rt_band_from_wkb), and set the flag. [[BR]]
 2.- In rt_band_set_pixel, rt_band_set_nodata reset the flag if needed.
 So, we avoid the out-of-synch situation, and the ST_BandIsNoData function
 only needs to check the flag value.
 Only 2 questions:
 - What should we do in case of offline bands? We could check the values
 using GDAL.[[BR]]
 - Correct me if I'm wrong, but we don't need the isnodata flag to be
 stored in WKB string
 I'll commit the code after testing it (and updating doc)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/593#comment:5>
