[postgis-devel] [PostGIS] #593: [raster] Add a ST_BandIsNoData function
trac at osgeo.org
Fri Jan 14 06:06:52 PST 2011
Reporter: pracine | Owner: jorgearevalo
Type: task | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by pracine):
As you might guess there is no easy way to set the flag in case a
ST_SetValue would set the last unique pixel withdata of a raster. There
should be a ST_BandIsNoData(rast, TRUE) that would scan every raster to
reset the flag if necessary. This function would be slow as it needs to
scan every pixels. This function would not be called everytime by pixel
setting functions but just some times by the user (like a VACUUM ANALYSE
sql command).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/593#comment:7>
