[postgis-devel] [PostGIS] #593: [raster] Add a ST_BandIsNoData function
trac at osgeo.org
Fri Jan 14 06:46:24 PST 2011
Reporter: pracine | Owner: jorgearevalo
Type: task | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by jorgearevalo):
Ok, summarizing:
- The isnodata flag must be persistent, as the hasnodata flag is (it must
be included in the WKB string)[[BR]]
- Keeping the isnodata flag synchronized is too slow if we pretend to
check it every time ST_SetValue / ST_SetBandNodataValue are called. We
need a way to force synchronization. For example, a special version of
ST_BandIsNoData function, with a boolean flag, to force this checking
(doubt: if no band is specified, I guess band 1 is used by default, no all
the raster bands). Other suggestions accepted.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/593#comment:10>
