[postgis-devel] [PostGIS] #771: Unable to query if geometry column has mixed srid
trac at osgeo.org
Fri Jan 14 19:43:05 PST 2011
Reporter: farrukhnajmi | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 1.4.3
Component: postgis | Version: 1.3.X
Resolution: wontfix | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => wontfix
Comment:
Farrukh,
I usually don't ask this, but why do you have mixed SRIDs in your table?
This is just in general bad and not something I think we care to support.
If you most have a network of tables queryable from a single table, then I
would suggest putting them in an inheritance structure such that each
table has its own SRID and then using a constraint exclusion check where
ST_SRID(geometry) = 4326. That way when you query those other tables will
be skipped anyway.
There are other issues with your query. within is not an indexed function
and has been removed in PostGIS 2.0, so please remove it and replace with
ST_Within. That will make your code both upward compatible and faster.
If you really must use a table with mixed srids, then you might be able to
trick the planner into processing your data in your desired order by
doing:
SELECT gvt.* FROM
(SELECT * FROM GeometryValueType WHERE ST_SRID(geometry) = 4326) AS gvt
WHERE
ST_Within(gvt.geometry,
ST_GeomFromText('POLYGON((-100 0, 0 0, 0 100, -100 100, -100 0))', 4326)
Also as I think someone mentioned in the thread -- you can put in an index
on your GeometryValueType table, but putting a spatial one actually
doesn't help much with your within since that doesn't use a spatial index
(though if you switched to ST_Within then it could take advantage of the
index). I would instead just put a functional index on SRID and also make
sure you have a spatial index on your geometry column
CREATE INDEX GeometryValueType_geom_srid_idx ON GeometryValueType using
btree
ST_SRID(geometry) ;
CREATE INDEX GeometryValueType_geom_geometry_gist_idx ON
GeometryValueType using gist(geometry) ;
Since index operations are generally faster, the planner would most likely
favor running an indexed operation first over a non-indexed one. Also
btree indexes are generally considered less costly so the planner would
favor checking that first over the spatial one. But again this all goes
into the category of tricking the planner which i try to avoid as it can
come and bite you later. Just keep your tables having separate srids is a
better solution.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/771#comment:2>
