[postgis-devel] [PostGIS] #780: Topology: adding a node over an edge could split the edge.
trac at osgeo.org
Mon Jan 17 13:01:59 PST 2011
Reporter: aperi2007 | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Keywords: |
Changes (by aperi2007):
* type: enhancement => defect
Comment:
This could be an error because the code try to raise an exception.
-- Check if any edge crosses this node
-- (endpoints are fine)
FOR rec IN EXECUTE 'SELECT edge_id FROM '
|| quote_ident(atopology) || '.edge '
|| 'WHERE ST_Crosses(' || quote_literal(apoint::text)
|| ', geom)'
LOOP
RAISE EXCEPTION
'An edge crosses the given node.';
END LOOP;
I don't know why this exception don't raise.
however change from enhancement to defect the ticket.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/780#comment:1>
