[postgis-devel] [PostGIS] #788: Topology: ST_NewEdgesSplit don't work with more edges connected
trac at osgeo.org
Tue Jan 18 12:13:23 PST 2011
Reporter: aperi2007 | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Keywords: |
I find a strange bug.
Starting from an empty topology:
DROP TABLE IF EXISTS SCHEMA_OUT.TEST;
CREATE TABLE SCHEMA_OUT.TEST(ID INTEGER PRIMARY KEY, CODICE TEXT);
SELECT topology.DropTopology('schema_topo');
SELECT topology.CreateTopology('schema_topo',3003, 0.00005);
SELECT topology.AddTopoGeometryColumn('schema_topo', 'schema_out', 'test',
'topo_line', 'LINE');
This code sql is working:
select
topology.AddEdge('schema_topo',ST_GeomFromEWKT('SRID=3003;LINESTRING(1 4,
2 5, 3 5, 4 7)'));
select topology.ST_newedgesSplit('schema_topo',1,
ST_GeomFromEWKT('SRID=3003;POINT(3 5)'));
but if the edge is connected to another edge.
The code don't work.
select
4 4)'));
select
2 5, 3 5, 4 7)'));
giving this error:
ERROR: SQL/MM Spatial exception - point not on edge
I use the r6670 version of postgis trunk.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/788>
