[postgis-devel] [PostGIS] #793: Topology: function GetNodeByPoint($1, $2, $3)
PostGIS trac at osgeo.org
Wed Jan 19 11:36:20 PST 2011
#793: Topology: function GetNodeByPoint($1,$2,$3)
 Reporter:  aperi2007    |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  topology     |     Version:  trunk
 Keywords:               |
 Has companion of GetEdgeByPoint I create also
 GetNodeByPoint to detect node before call the GetEdgeByPoint.
 GetNodeByPoint(atopology, point, tolerance)
 Retrieve a Node ID given a POINT and a tolerance
 tollerance = 0 mean exactly intersection
 Returns the integer ID if there is a Node on the Point.
 If there isn't any node in the Point, GetNodeByPoint return 0.
 if near the point there are two or more nodes it throw an exception.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/793>
