[postgis-devel] [PostGIS] #795: [raster] ST_Intersects raster documentation is confusing
PostGIS trac at osgeo.org
Wed Jan 19 13:33:06 PST 2011
 Reporter:  pracine         |       Owner:  pracine
     Type:  enhancement     |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Description changed by pracine:
Old description:
> The description says: "Returns true if any pixel in a raster band has a
> value that is not nodatavalue and that geometry region of the pixel
> intersects the geometry. If hasnodata is passed in, then it will use that
> to consider if it needs to analyze pixels (true) means analyze pixels, if
> the convexhull intersects the geometry. false means just return true if
> the convex hull of the raster intersects with the geometry. If hasnodata
> is omitted, it reads the value from the meta data of the raster."
> The last part of the sentence is false.
> Better proposition:
> -"Returns true if the geometry intersects with the raster. Nodata values
> are taken into account so that if the geometry intersects only with
> nodata values, the function returns false. hasnodata may modify this
> behavior: if set to false, nodata value are not taken into account and
> the function returns true as soon as the geometry intersects with the
> convex hull of the raster."
New description:
 The last sentence is false.
 Better proposition:
 are taken into account so that if the geometry intersects only with nodata
 values, the function returns false. hasnodata may modify this behavior: if
 set to false, nodata value are not taken into account and the function
 returns true as soon as the geometry intersects with the convex hull of
 the raster."
Ticket URL: <http://trac.osgeo.org/postgis/ticket/795#comment:1>
