#318: 900913->4326 Transform
Reporter: pramsey | Owner: mcayland
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.4.3
Component: postgis | Version: trunk
Keywords: |
Comment(by pbalomiri):
I got this bug too. I am working on os/x
The lib versions are:
template_postgis=# select * from postgis_version();
postgis_version
1.5 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
template_postgis=# select * from postgis_proj_version();
Rel. 4.7.1, 23 September 2009
The Error consistently appears when using SRID 4326:
wien_python=# select st_transform(st_transform('srid=4326;POINT(1
1)'::geometry, 900913), 4326);
ERROR: transform: couldn't project point (111319 111325 0): failed to
load NAD27-83 correction file (-38)
HINT: PostGIS was unable to transform the point because either no grid
shift files were found, or the point does not lie within the range for
which the grid shift is defined. Refer to the ST_Transform() section of
the PostGIS manual for details on how to configure PostGIS to alter this
behaviour.
For SRID 4267, however it works
wien_python=# select ST_Transform('SRID=900913;POINT(653103 6.63036e+06
0)'::geometry, 4267);
st_transform
01010000A0AB10000037CD83F1BA771740E31A12928E8649400000000000000000
(1 row)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/318#comment:23>
