[postgis-devel] [PostGIS] #797: ST_RemoveIsoNode does not throw an exception when passed a non-existent node
    trac at osgeo.org
    Thu Jan 20 23:18:05 PST 2011
node
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  low       |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 I can run this over and over again and get the same message:
 SELECT topology.ST_RemoveIsoNode('ma_topo',  7 ) As result;
          result
  Isolated node 7 removed
 I guess its isolated if it doesn't exist.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/797>
