[postgis-devel] [PostGIS] #799: Patch for casting geometry to	geography
    trac at osgeo.org
    Fri Jan 21 14:56:12 PST 2011
 Reporter:  smarshall    |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 1.5.3
Component:  postgis      |     Version:  1.5.X
 Keywords:               |
 Related to a post by Radu Ilie on Jan 20, 2011, I have a patch for casting
 from geometry to geography that solves his problem.  In particular, it
 will transform coordinates into the desired range for geography objects
 (-90 to 90 lat, -180 to 180 lon).  The previous version detected this
 problem, but simply issued an error if it occurred.
 The attached files add one new external function to the the postgis
 library (lwgeom_force_geodetic) and uses it in the function that casts
 geometry objects to geography objects (Datum geography_in).  The logic is
 a very simple clone of the lwgeom_check_geodetic function, except it fixes
 any descrepancies it finds.
 The API at the SQL level is not changed at all.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/799>
