[postgis-devel] [PostGIS] #805: populate_geometry_column(oid) fails
PostGIS trac at osgeo.org
Sat Jan 22 13:37:49 PST 2011
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Postgis manual [1] documents Populate_Geometry_Columns as taking an oid,
 then passes it a ::regclass in the example. Both calls fail against a
 view.
 [1] http://postgis.refractions.net/documentation/manual-
 svn/Populate_Geometry_Columns.html
Ticket URL: <https://trac.osgeo.org/postgis/ticket/805>
