[postgis-devel] [PostGIS] #808: shp2pgsql and encoding, something must be wrong
trac at osgeo.org
Tue Jan 25 21:10:38 PST 2011
Reporter: nicklas | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
Nicklas,
I'll give this one a try. My understanding was that shp2pgsql looks at
the encoding and translates the encoding from what was specified LATIN1 to
UTF8 so that by the time it gets to the .sql export it is already in
UTF-8. That is why you don't see anything different in the sql file
(except that the text should have been rewritten as UTF8). I could be
wrong though.
Anyrate that is my understanding why we compile shp2pgsql with iconv
support so it can do that translation. I never did quite understand why
we don't just have PostgreSQL do the translation (or rather I forgot why)
except its less portable (e.g. I think WIN1252 is valid on windows and not
on unix (or at least not PostgreSQL linux)
Have you tried the 1.5 version to see if this is just an issue in trunk?
So much stuff has changed in trunk.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/808#comment:1>
