[postgis-devel] [PostGIS] #810: Increare accuracy of area	calculation
    trac at osgeo.org
    Wed Jan 26 08:24:19 PST 2011
 Reporter:  hopfgartner  |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 1.5.3
Component:  postgis      |     Version:  1.5.X
 Keywords:               |
 In the case of polygons which are "far" away from the origin, as happens
 frequently in projected SRS, the applied change may increase the accuracy
 of the area calculation by some order of magnitude. Doing some tests on
 UTM32N geometries and comparing the result with the result calculated with
 a routine written with http://de.php.net/manual/en/book.bc.php the
 accuracy improved by 4 to 5 orders of magnitude.
 The patch is against PostGIS 1.5.2.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/810>
