[postgis-devel] [gdal-dev] Bogus <gml:Face> interpretation
strk strk at keybit.net
Sun Jan 30 05:05:30 PST 2011
On Sun, Jan 30, 2011 at 05:53:20PM +0530, Chaitanya kumar CH wrote:
> Thank you very much for pointing out the errors. I could blame it on the
> lack of enough sample data but that's just laziness. I should have read the
> specifications more throughly.
I noticed primarly because the GDAL interpretation would have not map
1:1 with the ISO SQL/MM topology model implemented in PostGIS.
> I see your first point but I need to dig deeper for the second.
The second point is not very clear in the GML document.
About TopoSurface, it says:
 `` gml:TopoSurface represents a homogeneous topological expression,
    a set of directed faces, which if realized are isomorphic to a
    geometric surface primitive. ''
I'm guessing that "realizing the set of" (F1,F2) means deploying it,
or "burning" it, "filling" it.... "unioning" it.
> >  | F1   |  F2  |
> > A surface/polygon formed by the two faces above (F1,F2) should be
> > represented as:
> >  <TopoSurface id="P1">
> >   <directedFace> <Face id="F1"/> </directedFace>
> >   <directedFace> <Face id="F2"/> </directedFace>
> >  </TopoSurface>
The simple geometry resulting from the above would be this:
     |     P1      |
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
