[postgis-devel] [PostGIS] #1080: cunit is crashing on test_ShpDumerDestroy()
trac at osgeo.org
Fri Jul 1 13:15:43 PDT 2011
Reporter: robe | Owner: mcayland
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: loader/dumper | Version: trunk
Keywords: |
Comment(by mcayland):
Hmmm that doesn't make much sense at all :( You don't need to upgrade
PostgreSQL as liblwgeom is being used as a standalone library. A couple of
things to try:
1) Did you try a complete "make clean" and "make" when you did an "svn
up"?
2) Can you get a gdb backtrace from the process as it crashes? Something
like:
make clean
./configure --with-gui
make
cd loader
make check
cd cunit
gdb cu_tester
Then from within gdb:
run
(crash)
bt
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1080#comment:5>
