[postgis-devel] [PostGIS] #1080: cunit is crashing on test_ShpDumerDestroy()
trac at osgeo.org
Fri Jul 1 14:17:01 PDT 2011
Reporter: robe | Owner: mcayland
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: loader/dumper | Version: trunk
Keywords: |
Comment(by robe):
MArk,
This is what run (crash) bt
gives:
Program received signal SIGSEGV, Segmentation fault.
0x6310224a in closePGconn () from c:\projects\pg\pg90\bin\libpq.dll
That's actually mingw libpq.dll though so maybe it wouldn't be an issue if
I switched path to my vc++ one. Though admittedly like I said it worked
before you last set of changes.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1080#comment:8>
