[postgis-devel] [PostGIS] #1080: cunit is crashing on test_ShpDumerDestroy()
PostGIS trac at osgeo.org
Fri Jul 1 15:02:34 PDT 2011
 Reporter:  robe           |       Owner:  mcayland
     Type:  defect         |      Status:  new
 Priority:  blocker        |   Milestone:  PostGIS 2.0.0
Component:  loader/dumper  |     Version:  trunk
 Keywords:                 |
Comment(by robe):
 Mark,
 Better but still crashes.  When I run in
 run (crash) bt mode -- it passes with flying colors.  What do you make of
 that?
 (gdb) run (crash) bt
 Starting program: c:\projects\PostGIS\trunk\loader\cunit/cu_tester.exe
 (crash) bt
 [New Thread 3372.0x1160]
      CUnit - A Unit testing framework for C - Version 2.1-0
      http://cunit.sourceforge.net/
 Suite: GUI Shapefile Loader File List Test
   Test: test_append_file() ... passed
   Test: test_find_file() ... passed
   Test: test_traversal() ... passed
   Test: test_remove_first() ... passed
   Test: test_remove_last() ... passed
   Test: test_remove_middle() ... passed
   Test: test_find_index() ... passed
 Suite: Shapefile Loader File pgsql2shp Test
   Test: test_ShpDumperCreate() ... passed
   Test: test_ShpDumperDestroy() ... passed
 --Run Summary: Type      Total     Ran  Passed  Failed
                suites        2       2     n/a       0
                tests         9       9       9       0
                asserts     124     124     124       0
 Program exited normally.
 (gdb)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1080#comment:10>
