[postgis-devel] [PostGIS] #1095: revise MIGRATION document
PostGIS trac at osgeo.org
Sat Jul 2 08:02:57 PDT 2011
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 I might be wrong but I think I saw geometry_column view definition falling
 back to using constraints, if available.
 The MIGRATION document says it doesn't.
 Also, I'm not sure the new geometry_column would return the mixed case
 thing. It's important that this document is in sync with
 the real code..
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1095>
