[postgis-devel] [PostGIS] #1008: Too many columns in select crashes pgsql2shp
trac at osgeo.org
Sat Jul 2 08:08:00 PDT 2011
Reporter: joshjordan | Owner: mcayland
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: loader/dumper | Version: trunk
Keywords: pgsql2shp |
Comment(by joshjordan):
That is a lot of added complexity to add a restriction of 254 fields. The
dbf file format has only a total record length limit, you may have over
255 fields as long as all of the field lengths add up to less than 2^16.
There is no other point in the postgis/mapserver stack where 255 fields is
the limit, so this change will break things for some people. If you want
to make this dynamically allocated, make the buffer the size of the input
string. We are just talking about 8kb that is only temporarily used and
then taken out of scope.
This issue can be put to rest by changing the 2kb static buffer to 8kb.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1008#comment:7>
