[postgis-devel] [PostGIS] #447: Changes in liblwgeom do not trigger rebuild of postgis shared object
trac at osgeo.org
Sat Jul 2 08:40:18 PDT 2011
Reporter: strk | Owner: mcayland
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by mcayland):
So you mean break out the headers to one .h file per .c file? Sure that
could work, but that's going to involve quite a bit more fiddling around
and there are still edge cases where it wouldn't work (e.g. if a struct
was declared in a .c rather than a .h file). Given the amount of work
involved, I'm inclined just to stick with the v2 patch unless you want to
do the extra refactoring?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/447#comment:9>
