[postgis-devel] [PostGIS] #1094: Fix broken curved regress tests
trac at osgeo.org
Mon Jul 4 02:43:52 PDT 2011
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by strk):
It looks like the relevant code is in liblwgeom/g_util.c, at the
geomtype_struct_array array of geomtype_struct objects.
Odd enough the comment above the array says that order is important in
that NO typename should occur within an entry before it but the rule is
immediately broken (GEOMETRY appears after GEOMETRYCOLLECTION)
I've also noticed that a static number (44) is used to size the array and
to later use it to scan it over. I'm attaching a patch which makes that
number computed by compiler so it's easier to add types in there.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1094#comment:1>
