[postgis-devel] [PostGIS] #1023: pglwgeom_getbox2d_p fails to compute a bounding box if a cache is missing (GSERIALIZED)
trac at osgeo.org
Mon Jul 4 08:36:35 PDT 2011
(GSERIALIZED)
Reporter: robe | Owner: pramsey
Type: defect | Status: closed
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
Alright, I've fixed this by adding the *compute_if_missing* logic into the
pglwgeom_getbox2d_p function, so that the underlying function retain their
documented behavior. r7582 documents pglwgeom_getbox2d_p in header, r7583
implements it correcly for G_SERIALIZED on.
Robe: can you confirm it fixes the topology tests your side ? (it does fix
mine againts 8.4.8)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1023#comment:15>
