[postgis-devel] [PostGIS] #1100: QuantumGIS no like pretty names
trac at osgeo.org
Tue Jul 5 04:40:18 PDT 2011
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
okay tried QGIS 1.7. Same issue doesn't like the casing when i choose to
only look in geometry_columns. Though works fine if I change my view. Like
I said, I'm not so worried about QGIS as I am worried about other tools or
people who have a lot of clients using QGIS and its a pain to get them to
upgrade to a newer.
So I still go with the - We should upper case things at the very least.
Paul -- would that work for you?
You can keep your PointZ, PointZM -- but in geometry_columns it has to be
uppercase POINTZ, POINTZM. 3D support is fairly new in most apps anyway
-- so not too big of a deal to get them used to POINTZ, POINTZM vs. POINT
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1100#comment:7>
