[postgis-devel] [PostGIS] #1106: Unsupported wkb format ?
trac at osgeo.org
Tue Jul 5 10:00:02 PDT 2011
Reporter: aperi2007 | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
try'ing to open with qgis some layer in an instance of postgis200 r7518
(for windows).
QGis don't show nothing in the canvas without report any error.
But If i try with OpenJump (more verbose of qgis)
it report this error:
com.vividsolutions.jts.io.ParseException: Unknown WKB type 48
at
com.vividsolutions.jts.io.WKBReader.readGeometry(WKBReader.java:186)
at com.vividsolutions.jts.io.WKBReader.read(WKBReader.java:140)
at com.vividsolutions.jts.io.WKBReader.read(WKBReader.java:121)
at
com.vividsolutions.jump.datastore.postgis.PostgisValueConverterFactory$WKBGeometryValueConverter.getValue(PostgisValueConverterFactory.java:73)
at
com.vividsolutions.jump.datastore.postgis.PostgisResultSetConverter.getFeature(PostgisResultSetConverter.java:47)
at
com.vividsolutions.jump.datastore.postgis.PostgisFeatureInputStream.getFeature(PostgisFeatureInputStream.java:78)
at
com.vividsolutions.jump.datastore.postgis.PostgisFeatureInputStream.readNext(PostgisFeatureInputStream.java:72)
at
com.vividsolutions.jump.io.BaseFeatureInputStream.hasNext(BaseFeatureInputStream.java:38)
at
com.vividsolutions.jump.workbench.ui.plugin.datastore.RunDatastoreQueryPlugIn.createLayer(RunDatastoreQueryPlugIn.java:66)
at
com.vividsolutions.jump.workbench.ui.plugin.datastore.RunDatastoreQueryPlugIn.createLayerable(RunDatastoreQueryPlugIn.java:30)
at
com.vividsolutions.jump.workbench.ui.plugin.datastore.AbstractAddDatastoreLayerPlugIn.run(AbstractAddDatastoreLayerPlugIn.java:32)
at
com.vividsolutions.jump.workbench.ui.task.TaskMonitorManager$TaskWrapper.run(TaskMonitorManager.java:151)
at java.lang.Thread.run(Unknown Source)
It seem there is some problem in the WKB format. Is it changed ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1106>
