[postgis-devel] [PostGIS] #1106: OpenJump (JTS): Unknown WKB type 48
trac at osgeo.org
Tue Jul 5 10:16:18 PDT 2011
Reporter: aperi2007 | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by strk):
Is this with data loaded with the _new_ postgis or pre-existing at the
time of postgis install ? The serialized format changed, so if you had
data in your db it may be misinterpreted.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1106#comment:2>
