[postgis-devel] [PostGIS] #1106: OpenJump (JTS): Unknown WKB type 48
trac at osgeo.org
Tue Jul 5 18:46:40 PDT 2011
Reporter: aperi2007 | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
If I compare the estimated extent to actual extent its way off.
select ST_Extent(geom) from tl_2010_25_zcta510;
yields:
BOX(-73.508142 41.230015,-69.923562 42.88679)
select st_estimated_extent('public','tl_2010_25_zcta510','geom');
Yields:
BOX(59157111109.9236 0,0 0)
which also doesn't seem to agree with QGIS
The other commands it runs is this:
Just in case I missed an important query -- this is the full log from when
I started using QGIS:
2011-07-05 21:34:59 EDT LOG: statement: set client_encoding to 'UNICODE'
2011-07-05 21:34:59 EDT LOG: statement: SET application_name='Quantum
GIS'
2011-07-05 21:34:59 EDT LOG: statement: select
f_table_name,f_table_schema,f_geometry_column,upper(type),pg_class.relkind
from geometry_columns,pg_class,pg_namespace where relname=f_table_name and
f_table_schema=nspname and pg_namespace.oid=pg_class.relnamespace and
has_schema_privilege(pg_namespace.nspname,'usage') and
has_table_privilege('"'||pg_namespace.nspname||'"."'||pg_class.relname||'"','select')
order by f_table_schema,f_table_name,f_geometry_column
f_table_name,f_table_schema,f_geography_column,upper(type),pg_class.relkind
from geography_columns,pg_class,pg_namespace where relname=f_table_name
and f_table_schema=nspname and pg_namespace.oid=pg_class.relnamespace and
order by f_table_schema,f_table_name,f_geography_column
pg_class.relname,pg_namespace.nspname,pg_attribute.attname,pg_class.relkind
from pg_attribute,pg_class,pg_namespace where
pg_namespace.oid=pg_class.relnamespace and pg_attribute.attrelid =
pg_class.oid and ( exists (select * from pg_type WHERE
pg_type.oid=pg_attribute.atttypid AND pg_type.typname IN
('geometry','geography')) or pg_attribute.atttypid IN (select oid FROM
pg_type a WHERE EXISTS (SELECT * FROM pg_type b WHERE a.typbasetype=b.oid
AND b.typname IN ('geometry','geography')))) and has_schema_privilege(
pg_namespace.nspname, 'usage' ) and has_table_privilege( '"' ||
pg_namespace.nspname || '"."' || pg_class.relname || '"', 'select' ) and
not exists (select * from geometry_columns WHERE
pg_namespace.nspname=f_table_schema AND pg_class.relname=f_table_name) and
not exists (select * from geography_columns WHERE
pg_class.relkind in( 'v', 'r' )
GIS'
2011-07-05 21:34:59 EDT LOG: statement: select distinct case when
geometrytype("extent") IN ('POINT','MULTIPOINT') THEN 'POINT' when
geometrytype("extent") IN ('LINESTRING','MULTILINESTRING') THEN
'LINESTRING' when geometrytype("extent") IN ('POLYGON','MULTIPOLYGON')
THEN 'POLYGON' end from "public"."raster_columns"
2011-07-05 21:35:02 EDT LOG: statement: set client_encoding to 'UNICODE'
2011-07-05 21:35:02 EDT LOG: statement: select postgis_version()
postgis_geos_version(),postgis_proj_version()
2011-07-05 21:35:02 EDT LOG: statement: SET application_name='Quantum
GIS'
2011-07-05 21:35:02 EDT LOG: statement: select * from
"public"."tl_2010_25_zcta510" limit 1
2011-07-05 21:35:02 EDT LOG: statement: SELECT pg_is_in_recovery()
has_table_privilege('"public"."tl_2010_25_zcta510"','DELETE'),has_any_column_privilege('"public"."tl_2010_25_zcta510"','UPDATE'),has_column_privilege('"public"."tl_2010_25_zcta510"','geom','UPDATE'),has_table_privilege('"public"."tl_2010_25_zcta510"','INSERT'),current_schema()
2011-07-05 21:35:02 EDT LOG: statement: SELECT 1 FROM
pg_class,pg_namespace WHERE pg_class.relnamespace=pg_namespace.oid AND
pg_get_userbyid(relowner)=current_user AND relname='tl_2010_25_zcta510'
AND nspname='public'
2011-07-05 21:35:02 EDT LOG: statement: select type,srid from
geometry_columns where f_table_name='tl_2010_25_zcta510' and
f_geometry_column='geom' and f_table_schema='public'
regclass('"public"."tl_2010_25_zcta510"')::oid
2011-07-05 21:35:02 EDT LOG: statement: BEGIN READ ONLY
2011-07-05 21:35:02 EDT LOG: statement: declare oidcursor binary cursor
for select regclass('"public"."tl_2010_25_zcta510"')::oid
2011-07-05 21:35:02 EDT LOG: statement: fetch forward 1 from oidcursor
2011-07-05 21:35:02 EDT LOG: statement: CLOSE oidcursor
2011-07-05 21:35:02 EDT LOG: statement: COMMIT
2011-07-05 21:35:02 EDT LOG: statement: select indkey from pg_index where
indisunique and indrelid=regclass('"public"."tl_2010_25_zcta510"')::oid
and indpred is null
2011-07-05 21:35:02 EDT LOG: statement: select attname,pg_type.typname
from pg_attribute,pg_type where atttypid=pg_type.oid and attnum=1 and
attrelid=regclass('"public"."tl_2010_25_zcta510"')
2011-07-05 21:35:02 EDT LOG: statement: SELECT column_default FROM
information_schema.columns WHERE column_default IS NOT NULL AND
table_schema = 'public' AND table_name = 'tl_2010_25_zcta510' AND
column_name = 'gid'
2011-07-05 21:35:02 EDT LOG: statement: SELECT description FROM
pg_description WHERE objoid=135250 AND objsubid=0
"public"."tl_2010_25_zcta510" limit 0
typname,typtype,typelem,typlen FROM pg_type WHERE oid=23
2011-07-05 21:35:02 EDT LOG: statement: SELECT attnum FROM pg_attribute
WHERE attrelid=135250 AND attname='gid'
pg_description WHERE objoid=135250 AND objsubid=1
typname,typtype,typelem,typlen FROM pg_type WHERE oid=1043
WHERE attrelid=135250 AND attname='statefp10'
pg_description WHERE objoid=135250 AND objsubid=2
WHERE attrelid=135250 AND attname='zcta5ce10'
pg_description WHERE objoid=135250 AND objsubid=3
WHERE attrelid=135250 AND attname='geoid10'
pg_description WHERE objoid=135250 AND objsubid=4
WHERE attrelid=135250 AND attname='classfp10'
pg_description WHERE objoid=135250 AND objsubid=5
WHERE attrelid=135250 AND attname='mtfcc10'
pg_description WHERE objoid=135250 AND objsubid=6
WHERE attrelid=135250 AND attname='funcstat10'
pg_description WHERE objoid=135250 AND objsubid=7
typname,typtype,typelem,typlen FROM pg_type WHERE oid=701
WHERE attrelid=135250 AND attname='aland10'
pg_description WHERE objoid=135250 AND objsubid=8
WHERE attrelid=135250 AND attname='awater10'
pg_description WHERE objoid=135250 AND objsubid=9
WHERE attrelid=135250 AND attname='intptlat10'
pg_description WHERE objoid=135250 AND objsubid=10
WHERE attrelid=135250 AND attname='intptlon10'
pg_description WHERE objoid=135250 AND objsubid=11
WHERE attrelid=135250 AND attname='partflg10'
pg_description WHERE objoid=135250 AND objsubid=12
2011-07-05 21:35:02 EDT LOG: statement: set client_min_messages to error
2011-07-05 21:35:02 EDT LOG: statement: SELECT COUNT(*) FROM pg_stats
WHERE schemaname='public' AND tablename='tl_2010_25_zcta510' AND
attname='geom'
2011-07-05 21:35:02 EDT LOG: statement: select reltuples::int from
pg_catalog.pg_class where
oid=regclass('"public"."tl_2010_25_zcta510"')::oid
2011-07-05 21:35:02 EDT LOG: statement: declare qgisf2 binary cursor for
select "gid",st_asbinary("geom",'NDR') from "public"."tl_2010_25_zcta510"
where "geom" && st_setsrid('BOX3D(-1.6754578754578755 -1.0000000000000000,
1.6754578754578755 1.0000000000000000)'::box3d,4269)
2011-07-05 21:35:02 EDT LOG: statement: fetch forward 200 from qgisf2
2011-07-05 21:35:02 EDT LOG: statement: CLOSE qgisf2
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1106#comment:9>
