[postgis-devel] [PostGIS] #1106: OpenJump (JTS): Unknown WKB type 48
PostGIS trac at osgeo.org
Tue Jul 5 19:06:52 PDT 2011
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  critical   |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by robe):
 Andrea -- how are you querying OpenJump?  I don't get the error you have
 above about wkb type, but I'm running a slightly newer PostGIS.  With ad-
 hoc tool it gives that error if you don't do an ST_AsBinary on the column
 but that has always been the case.
 SO:
 -- this works
 SELECT ST_AsBinary(geom)
 FROM tl_2010_25_zcta510
 -- this will give a type 48 error in ad-hoc tool
 SELECT geom
 FROM tl_2010_25_zcta510;
 FWIW -- if I install the missing legacy functions, my OpenJump works fine
 with the add data store layer option also.  So I don't think there is an
 issue with OpenJump, just QGIS.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1106#comment:11>
