[postgis-devel] [PostGIS] #1113: "Old" Road name not found
PostGIS trac at osgeo.org
Wed Jul 6 13:41:29 PDT 2011
 Reporter:  mikepease       |       Owner:  robe
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  tiger geocoder  |     Version:  1.5.X
 Keywords:                  |
 There are several roads in Minnesota that were replaced by a newer road or
 highway.  The older road is still there, but the name was changed to "Old
 Yada Yada Road".
 The geocoder is not finding these "Old" roads.  But it finds them if you
 take out the word "Old" from the street name.  Some examples:
 --8040 OLD CEDAR AVE S, BLOOMINGTON, MN 55425
 --17405 Old Rockford Rd, Plymouth, MN 55446
 --198 OLD CONSTANCE BLVD, ANDOVER, MN 55304
 --fails with "Old"
 select abs(ST_X(geomout)::numeric(8,5)) || 'W, ' ||
 ST_Y(geomout)::numeric(8,5) || 'N' as lat_lon, *
 from geocode('8040 OLD CEDAR AVE S, BLOOMINGTON, MN 55425')
 --works without "Old"
 from geocode('8040 CEDAR AVE S, BLOOMINGTON, MN 55425')
 --fails with "Old"
 from geocode('17405 Old Rockford Rd, Plymouth, MN 55446')
 from geocode('17405 Rockford Rd, Plymouth, MN 55446')
 --fails with "Old"
 from geocode('198 OLD CONSTANCE BLVD, ANDOVER, MN 55304')
 from geocode('198 CONSTANCE BLVD, ANDOVER, MN 55304')
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1113>
