[postgis-devel] [PostGIS] #1100: QuantumGIS no like pretty names
PostGIS trac at osgeo.org
Fri Jul 8 01:34:04 PDT 2011
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  blocker  |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 at r7621 -  Okay made geometry_columns.type fields uppercase and stripped
 off the Z and ZM flags at end so now its fully backward compatible except
 not being able to update.
 I can now see my tiger tables in quantum, but my zoom to extent still
 doesn't seem to work unless I do a build filter first.  I'm not absolutely
 sure that was working before -- could be my dataset.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1100#comment:10>
