[postgis-devel] [PostGIS] #1097: postgis upgrade scripts not outputting geometry_columns
trac at osgeo.org
Fri Jul 8 01:44:17 PDT 2011
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
Okay I give up on this one. Can one of you perl geeks take acare of this.
I assume it's jsut the postgis_proc_upgrade.pl that needs to be changed.
I tried adding geometry_columns to the top and tried to get rid of the
conditional check on version in create or replace view. All that happened
is my regress managed to break and was generating a postgis.sql that
didn't have the regress postgis.lib (was pointing at my produciton). Not
sure how those 2 are connected.
Anyrate:
1) There is no reason WHAT SO EVER I can think of to not run
CREATE OR REPLACE VIEW even on a minor upgrade, because as long as the
column names and types don't change, then even dependent objects will be
unaffected.
on a minor upgrade
2) Fro a major upgrade we might have to do a drop REPLACE, but lets just
assume for simplicity we will never change the outter exterior (types of
columns, column names) except possibly to add columns at the end. Adding
columns at the end is doable with a CREATE OR REPLACe
so short -- we should always do a CREATE OR REPLACE VIEW for both minor
and major
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1097#comment:1>
