[postgis-devel] [PostGIS] #1109: Lake Drive is good; Lake DR - not so good
trac at osgeo.org
Fri Jul 8 01:49:55 PDT 2011
Reporter: mikepease | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: 1.5.X
Keywords: |
Comment(by robe):
yap that was what I was thinking with a rating object weight you pass in.
The rates are essentially just weighting the elements of the normalized
address so the rate object I had in mind is similar to your favorOptions
and would take on more or less the same shape as addy except have number
weights for the fields instead of the value.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1109#comment:11>
