[postgis-devel] [PostGIS] #1117: ST_OffsetCurve function definition inconsistent with documentation
PostGIS trac at osgeo.org
Sat Jul 9 09:17:58 PDT 2011
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 Oops, I copied from _ST_Buffer, which is taking a cstring.
 I do see that taking a cstring seems to be a problem (see also the
 ST_Buffer wrappers) so maybe we should convert both _ST_Buffer and
 ST_OffsetCurve to take text instead.
 The cstring type seems to be only used (beside these two) for canonical
 text input/output of types.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1117#comment:1>
