[postgis-devel] [PostGIS] #1120: ST_Line_Interpolate_Point does not handle M value
trac at osgeo.org
Tue Jul 12 12:54:51 PDT 2011
Reporter: falcor | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Keywords: |
The reference manuals says "Since release 1.1.1 this function also
interpolates M and Z values (when present), while prior releases set them
to 0.0.", but it appears that only the Z values is interpolated.
To test, use the example query on the page:
# SELECT ST_AsEWKT(ST_Line_Interpolate_Point(the_line, 0.5)) FROM
(SELECT ST_GeomFromEWKT('LINESTRING(1 2 3, 4 5 6, 6 7 8)') as the_line) As
foo;
st_asewkt
POINT(3.5 4.5 5.5)
Now change LINESTRING to LINESTRINGM and see that the M value returned is
0.
(SELECT ST_GeomFromEWKT('LINESTRINGM(1 2 3, 4 5 6, 6 7 8)') as the_line)
As foo;
st_asewkt
POINTM(3.5 4.5 0)
This was tested against PostGIS 1.4.2 and 1.5.2 with a 0 M value in both.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1120>
