[postgis-devel] [PostGIS] #343: History Table Enhancements
trac at osgeo.org
Wed Jul 13 17:49:27 PDT 2011
Reporter: pimpaa | Owner: pimpaa
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: History Tables |
Comment(by pimpaa):
Heres is the new version for the history table implementation.
Changes:
- Altered the return of the functions to be a varchar, to comply with
other similar functions. My idea here was to do this at the lowest
possible level and join all information on the top level functions, but
I'm quite busy these days, so I hardcoded some of the return information.
There's room for improvement here, as I said, collecting more detailed
information and outputting to the user.
- Fixed the bug reported by Regina. UPDATEs are logged as UPDATED,
deletes as DELETED and INSERTS as INSERT (I'm thinking INSERTED here would
fit better). I'm open to suggestions.
- The current_version number in history table should point at the current
history version which those old records point to. This is some sort of
bug. Now they are pointing to the current primary key on the actual table,
so we get a lot of duplicated information. The PK is already listed, so
it's not necessary.
- I've created one single test. The plan is to split it up into more
tests. Advice would be great.
- The functions now are:
postgis_create_history(schema,table,pk field) - this will create the
history table for the first time and start logging;
postgis_enable_history(schema,table) - enables history logging for a
certain table if this table is already listed on historic_information (ie.
postgis_create_history already ran at some point). this will recreate the
logging rules.
postgis_disable_history(schema,table) - disables history logging for a
table that is listed in historic_information. this function only updates
the historic_information table and drops the logging rules.
postgis_drop_history(schema,table) - this will purge all history
information for a certain table. this will drop historic table and delete
it's records from geometry_columns and historic_information.
I would like to hear your comments and critics.
Thanks
Ticket URL: <http://trac.osgeo.org/postgis/ticket/343#comment:13>
