[postgis-devel] [PostGIS] #1135: Small regression test updates
trac at osgeo.org
Wed Jul 20 11:27:21 PDT 2011
Reporter: ads | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Keywords: |
As posted earlier on the devel mailinglist:
http://postgis.refractions.net/pipermail/postgis-
devel/2010-October/014441.html
(the date is invalid because of server issues)
here are two patches for the regression tests.
One patch is for 1.5.3, one for 2.0.0SVN.
From my mail to the mailinglist:
----- copy -----
we recently implemented PostGIS in Greenplum (a PostgreSQL fork).
The regression tests throwed some errors on us, but mainly only a
different output order in the affected .expected files.
Greenplum is a distributed shared-nothing architecture. Unlike
PostgreSQL, we will always get the rows in a different order - unless we
order them explicitely, like it is required in the SQL standard.
Thinking about it, there is a (although very small) chance, that
synchronized sequentiell scans in 8.3 and above will also break these
regression tests - as example, if a backup is running at the same time.
Attached you can find a small patch which adds "order by 1" in some of the
regression tests, and also changes the output order in some of the
.expected files. The data itself is not changed. The patch works with
PostgreSQL 9.04 and PostGIS 1.5.3.
----- copy -----
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1135>
