[postgis-devel] [PostGIS] #1141: [raster] ST_AsRaster
PostGIS trac at osgeo.org
Fri Jul 22 10:27:53 PDT 2011
 Reporter:  dustymugs       |       Owner:  pracine
     Type:  task            |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 ST_AsRaster provides the ability convert a geometry into a raster.  To
 create the raster, the X and Y scale or the width and height of the raster
 must be provided.
 The output raster will be in the same coordinate system as the source
 geometry.  The only exception is for ST_AsRaster variations with a raster
 input parameter.
 1. ST_AsRaster(
   geom geometry,[[BR]]
   scalex double precision, scaley double precision,[[BR]]
   pixeltype text[] DEFAULT ARRAY!['8BUI']::text[],[[BR]]
   value double precision[] DEFAULT ARRAY![1]::double precision[],[[BR]]
   nodataval double precision[] DEFAULT ARRAY![0]::double
 precision[],[[BR]]
   upperleftx double precision DEFAULT NULL, upperlefty double precision
 DEFAULT NULL,[[BR]]
   gridx double precision DEFAULT NULL, gridy double precision DEFAULT
 NULL,[[BR]]
   skewx double precision DEFAULT 0, skewy double precision DEFAULT 0
 ) -> raster
   geom: the geometry to convert to a raster.  Can be any valid PostGIS
 geometry.
   scalex: the scale/pixel size in the X axis of the output raster. If
 scalex and scaley are zero (0), the output raster's scale will be
 autocomputed.
   scaley: the scale/pixel size in the Y axis of the output raster. If
 autocomputed.
   pixeltype: array of pixel types for each band.  Each array element is a
 band.
   value: array of values to burn into the raster for the geometry.  Each
 array element is a band.
   nodataval: array of nodata values to burn into the raster.  Each array
 element is a band.  If an array element is null, that band will not have a
 nodata value.
   upperleftx: the X value of the upper-left corner of the output raster
   upperlefty: the Y value of the upper-left corner of the output raster
   gridx: the X coordinate of a point on the grid to which the raster will
 be aligned. Value is in the raster's world coordinates.
   gridy: the Y coordinate of a point on the grid to which the raster will
   skewx: the skew along the X axis of the raster.  by default, the skew
 along the X axis is zero.
   skewy: the skew along the Y axis of the raster.  by default, the skew
 ''If the number of elements for pixeltype, value and nodataval do not
 match, the minimum number of elements will be used.''
 2. ST_AsRaster(
   width integer, height integer,[[BR]]
 precision[],[[BR]]
 DEFAULT NULL,[[BR]]
 NULL,[[BR]]
 ) -> raster
   width: the number of pixels per line in the raster
   height: the number of lines in the raster
 3. ST_AsRaster(
   pixeltype text,[[BR]]
   value double precision DEFAULT 1,[[BR]]
   nodataval double precision DEFAULT 0,[[BR]]
 DEFAULT NULL,[[BR]]
 NULL,[[BR]]
 ) -> raster
   Like !#1 but pixeltype, value and nodataval are simple values rather
 than arrays.  Therefore, the output raster will only have one band.
 4. ST_AsRaster(
 DEFAULT NULL,[[BR]]
 NULL,[[BR]]
 ) -> raster
 5. ST_AsRaster(
   ref raster,[[BR]]
   nodataval double precision[] DEFAULT ARRAY![0]::double precision[]
 ) -> raster
   ref: the reference raster whose scalex, scaley, skewx, skewy and srid
 will be applied to the output raster.  The upperleft corner of the
 reference raster is used to align the output raster to the same grid.
 6. ST_AsRaster(
   ref raster,[[BR]]
 ) -> raster
   Like !#5 but pixeltype, value and nodataval are simple values rather
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1141>
