[postgis-devel] [PostGIS] #1141: [raster] ST_AsRaster
trac at osgeo.org
Fri Jul 22 11:22:31 PDT 2011
Reporter: dustymugs | Owner: dustymugs
Type: task | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by pracine):
That means, in every variant, two parameters are useless? Why not making
different variant for grid defined by upperleft and grid defined by the
grid parameter?
It's true that there is a parameter type conflict in the variants I
proposed:
4) fl fl 5) fl fl fl 6) fl fl fl fl 7) fl fl fl fl fl fl
8) fl fl int int 9) fl fl int int fl fl fl fl
but if you remove variant 4) it should fix the conflict...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1141#comment:5>
