[postgis-devel] [PostGIS] #1141: [raster] ST_AsRaster
PostGIS trac at osgeo.org
Fri Jul 22 15:17:24 PDT 2011
 Reporter:  dustymugs       |       Owner:  dustymugs
     Type:  task            |      Status:  assigned
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by dustymugs):
 I agree that having two useless parameters is undesirable.  The way I
 prototyped the function is so that the function can be called as easily as
 possible, which is to provide the geometry and either the scale or
 width/height.
 I've refactored the functions to those below.  I basically moved the gridx
 and gridy parameters up in the list of parameters as I think that it is
 easier to specify a grid point to align to rather than deal with the
 upper-left corner of the raster as the grid point could be gotten from the
 coverage or raster to align with.
 1. ST_AsRaster(
         geom geometry,
         scalex double precision, scaley double precision,
         gridx double precision DEFAULT NULL, gridy double precision
 DEFAULT NULL,
         pixeltype text[] DEFAULT ARRAY['8BUI']::text[],
         value double precision[] DEFAULT ARRAY[1]::double precision[],
         nodataval double precision[] DEFAULT ARRAY[0]::double precision[],
         skewx double precision DEFAULT 0, skewy double precision DEFAULT 0
 ) -> raster
 2. ST_AsRaster(
         geom geometry,
         pixeltype text[],
         upperleftx double precision DEFAULT NULL, upperlefty double
 ) -> raster
 3. ST_AsRaster(
         geom geometry,
         width integer, height integer,
 DEFAULT NULL,
 ) -> raster
 4. ST_AsRaster(
         geom geometry,
         pixeltype text[],
 ) -> raster
 5. ST_AsRaster(
         geom geometry,
         gridx double precision, gridy double precision,
         pixeltype text,
         value double precision DEFAULT 1,
         nodataval double precision DEFAULT 0,
 ) -> raster
 6. ST_AsRaster(
         geom geometry,
         pixeltype text,
 ) -> raster
 7. ST_AsRaster(
         geom geometry,
         pixeltype text,
 ) -> raster
 8. ST_AsRaster(
         geom geometry,
         pixeltype text,
 ) -> raster
 9. ST_AsRaster(
         geom geometry,
         ref raster,
 ) -> raster
 10. ST_AsRaster(
         geom geometry,
         ref raster,
         pixeltype text,
 ) -> raster
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1141#comment:7>
