[postgis-devel] [PostGIS] #1050: Add GEOS spatial operations to liblwgeom
trac at osgeo.org
Wed Jul 27 09:59:27 PDT 2011
Reporter: bnordgren | Owner: strk
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by bnordgren):
The current patch passes all the cunit tests. My development environment
won't currently run any tests which require connecting to a live server
(see dev list). A cursory glance suggests that there are no cunit tests
for `intersection`, `union`, etc. Perhaps any sql based tests should be
ported to cunit in the future. They should also remain as sql based tests,
however, as there is plenty of opportunity to cut and paste something
incorrectly.
New patch is against r7683 and has "moved" instead of "copied" the
relevant functions.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1050#comment:10>
