[postgis-devel] [PostGIS] #1058: [raster] Two-raster spatial operations framework proposal
trac at osgeo.org
Sat Jul 30 11:42:50 PDT 2011
Reporter: bnordgren | Owner: pracine
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by bnordgren):
Most recent patch reflects "option 3" on #1133. It applies against r7683
which has already had patches from #1050 and #1053 applied.
This patch:
* Moves the `PG_MODULE_MAGIC` and `lwgeom_init_allocators` to libcommon.
(The latter uses the main postgis memory management functions.)
* Leverages the `libcommon` and `liblwgeom` static libraries.
* Requires the GEOS operations on the LWGEOM type (moved to `liblwgeom`
in #1050)
* Requires the transformation API cache used by postgis (moved to
`libcommon` in #1053).
All cunit tests pass except for loader/Latin1, which fails on all
instances of r7683 on my platform. Regression tests pass. I did not see it
run additional regression tests for raster (only for postgis).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1058#comment:15>
