[postgis-devel] [PostGIS] #650: [raster] st_dumpaspolygon create int values
trac at osgeo.org
Wed Jun 1 21:35:42 PDT 2011
Reporter: etiennebr | Owner: jorgearevalo
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Resolution: fixed | Keywords:
Comment(by dustymugs):
From the looks of it, there is no way to specify a rounding factor.
Personally, I have a different question. By the looks of it, you need
GDAL trunk revision 22476 to make use of the functionality and run some of
the tests. So, is PostGIS Raster going to set the minimum required
version of GDAL raster to whatever point release includes this specific
revision?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/650#comment:15>
