[postgis-devel] [PostGIS] #1005: [raster] Problem with ST_SummaryStats(text, text) results
trac at osgeo.org
Wed Jun 8 05:49:00 PDT 2011
Reporter: pracine | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by pracine):
Replying to [comment:2 dustymugs]:
> As for the standard deviation of a coverage, I do confirm the issue. To
do this correctly will require going over the coverage table twice, once
for the coverage's mean and the second for the mean's standard deviation.
So, do we want to be accurate at the expense of speed or be close at the
expense of accuracy? Maybe we need to add an option flagging whether or
not to get the accurate standard deviation for a coverage?
1) We must be clear about that in the doc and we should provide (a link
to?) the method used to get the approximative value
2) I agree with the option. Default should be the approximate value.
I thought the method you found (one pass stddev) provided accurate result.
I thought we added the sum to be able to get an accurate stddev. How does
it work for one tile? Is the stddev accurate for one tile?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1005#comment:4>
