[postgis-devel] [PostGIS] #1005: [raster] Problem with ST_SummaryStats(text, text) results
trac at osgeo.org
Wed Jun 8 12:31:37 PDT 2011
Reporter: pracine | Owner: dustymugs
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by robe):
how big is your dataset. of course as you mentioned before its calling the
function for each each column in the bad case.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1005#comment:12>
