[postgis-devel] [PostGIS] #925: [raster] ST_Transform
trac at osgeo.org
Wed Jun 8 15:21:10 PDT 2011
Reporter: dustymugs | Owner: dustymugs
Type: task | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: history |
Comment(by robe):
I have no idea -- I didn't see a configuration option in GDAL to allow me
to specify the proj library (I recall that when I compiled proj 4.7 it did
name the file libproj-0.dll).
I went ahead and tested the examples in my PostgreSQL 9.1 install. It
doesn't give an error but returns the wrong answer. Maybe new gdal
expects proj 4.7 or above though it should error out and its not. I'm
running proj 4.6.1.
So via psql -
SELECT
ST_SRID(rast),
ST_Width(rast),
ST_Height(rast),
ST_NumBands(rast),
ST_ScaleX(rast),
ST_ScaleY(rast),
ST_Count(rast),
ST_Mean(rast)
FROM (SELECT ST_Transform(
ST_SetValue(
ST_SetValue(
ST_SetValue(
ST_AddBand(
ST_MakeEmptyRaster(10, 10,
-500000, 600000, 1000, 1000, 0, 0, 1002163)
, 1, '64BF', 0, 0
, 1, 1, 1, -10
, 1, 5, 4, 0
, 1, 5, 5, 3.14159
, 1003310) AS rast
) foo;
Give me this -- fair enough right:
st_srid | st_width | st_height | st_numbands | st_scalex | st_scaley |
st_count
| st_mean
1003310 | 10 | 10 | 1 | 1000 | -1000 |
2 | -3.429205
Note in BBorie's regress, he gets a width of 12 , scale x and scale y
changed and I'm getting 10 back like its not doing anything but not
erroring out either.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/925#comment:25>
