[postgis-devel] [PostGIS] #925: [raster] ST_Transform
trac at osgeo.org
Thu Jun 9 06:37:38 PDT 2011
Reporter: dustymugs | Owner: dustymugs
Type: task | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: history |
Comment(by mcayland):
Hmmm so do you have a static or a dynamic PROJ.4 link on Windows? The
trick to producing the DLL is this line on
http://trac.osgeo.org/postgis/wiki/DevWikiWinMingWSys_14_15:
gcc -shared -o libproj.dll -Wl,--out-implib=libproj.dll.a -Wl,--export-
all-symbols -Wl,--enable-auto-import -Wl,--whole-archive libproj.a -Wl
,--no-whole-archive /c/mingw/lib/libmingw32.a
Perhaps you need to temporarily rename libproj.a after you've done this in
order to prevent raster finding the static version?
In terms of the PROJ.4 search paths for grid files, Regina mentioned this:
ttp://trac.osgeo.org/postgis/browser/trunk/postgis/lwgeom_transform.c#L602.
All this does is ADD this to the search path, so PROJ.4 will still search
in other locations. I believe that these are currently the value of the
PROJ4LIB environment variable (if it exists), then the specified search
path, and then finally a fixed location generated at compile time
(typically C:\PROJ\LIB).
Hope this helps you guys :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/925#comment:37>
